VarkGripper
Jun 08, 2017Aspirant
Latest Firmware 4.1.16
I ran the Firmware 4.1.16 that Netgar issed and followed the normal process and nwo I am unabel to gian acces to the Admin page. I can see the data and can view in in SSH but not in the Admin page an...
- Jun 09, 2017
Thanks for the help. Still no go and have decided to do a Factory re-set. The steps got very close and at one point it was send, me emails saying nothing or "Dead. This volume is no longer available. (VarkWork)"
Now rebuilding Raid. I will accept this as a solution.
Roger
Jun 08, 2017Guru - Experienced User
I think must have you cd'd somewhere else when you logged in with ssh. Try again, this time do a cd // first.
VarkGripper
Now set at root of file system
VarkWork://# ls
backup bin c dev etc frontview home HU3A initrd lib lost+found media mnt opt proc ramfs root sbin sys tmp USB usr var Webroot
VarkWork://# df . -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 1.9G 658M 1.2G 34% /
VarkWork://# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 128000 17066 110934 14% /
VarkWork://#
- StephenBJun 08, 2017Guru - Experienced User
/dev/md0 128000 17066 110934 14% /Great. Sometimes a fillling OS partition can cause your symptoms. But that's not your situation.
Did you try using RAIDar to check the status?
- VarkGripperJun 08, 2017Aspirant(Green LED) a0:63:91:65:47:52 ReadyNAS 202 VarkHome 192.168.1.126 6.7.4 (Green LED) c4:3d:c7:6a:9d:8a ReadyNAS Duo VarkWork 192.168.1.89 4.1.16 Volume and Disk Status all ok When I try and re-start apache2 " /etc/init.d/apache2 start" Starting web server: apache2install: invalid user `www-data' apache2: Could not open configuration file /etc/apache2/apache2.conf: No such file or directory failed! www-data user not in user list and apache2.conf not found by using "find -name apache2.conf
- mdgm-ntgrJun 08, 2017NETGEAR Employee Retired
Try
# apache-ssl -f /etc/frontview/apache/httpd.conf -t && apache-ssl -f /etc/frontview/apache/httpd.conf -k restart
You may also want to look at the end of /var/log/frontview/error.log
# tail -n 20 /var/log/frontview/error.log
Do you have any add-ons installed?
