VarkGripper
Jun 08, 2017Aspirant
Latest Firmware 4.1.16
I ran the Firmware 4.1.16 that Netgar issed and followed the normal process and nwo I am unabel to gian acces to the Admin page. I can see the data and can view in in SSH but not in the Admin page an...
- Jun 09, 2017
Thanks for the help. Still no go and have decided to do a Factory re-set. The steps got very close and at one point it was send, me emails saying nothing or "Dead. This volume is no longer available. (VarkWork)"
Now rebuilding Raid. I will accept this as a solution.
Roger
mdgm-ntgr
Jun 09, 2017NETGEAR Employee Retired
As I suspected you need to re-install the PHP add-on manually.
Copy the add-on to a share on the NAS then use cp to copy it to /tmp
Then do e.g.
# cd /tmp # mkdir /tmp/PHP123 # cd /tmp/PHP123 # dd if=/tmp/PHP_addon.bin skip=1 | tar -xv (N.B. replace PHP_addon.bin with whatever the addon is called) # sh install.sh # cd
You can then try restarting apache using the command I gave above again and if it still doesn't work look for what new errors you get.
There is an APT add-on but installing that and using that won't solve this problem and could even make things worse if used inappropriately.
VarkGripper
Jun 09, 2017Aspirant
Roger
