shauno100
Jul 09, 2016Tutor
LED Control - ReadyNAS RN102
Hi,
I have been trying to work out how to turn on/off the LEDs on the front panel of the RN102 which i have successfully achieved by running the following commands
POWER LED
echo 0 > /s...
mdgm-ntgr
Aug 12, 2016NETGEAR Employee Retired
This is by design. Turning off the Activity LED is not possible. You may wish to cover it with electrical tape of it annoys you.
- StephenBAug 13, 2016Guru - Experienced User
Users will never agree on lights. Some want them bright, some want them dim, some want them off. It all depends on where they put the product.
The only way that really works for everyone is for Netgear to provide some options in the web UI. Some of the newer routers have lighting controls, it would be good if the NAS did also.
shauno100 you might want to vote for the idea here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Add-the-ability-to-Dim-the-Power-Light/idi-p/1049769 You do that by clicking on the up arrow.
