ironbut
Jun 11, 2018Aspirant
Left hand bay not working on RND2110 V2
Hi, I have two 1TB drives in a mirror. The left hand one failed (click of death), so I took it out and the NAS is now working with a single drive in the right hand bay.
When I try the good driv...
- Jun 11, 2018
The system should boot with the remaining drive in either bay (though you do need to move the drive with the NAS powered down).
You might try disconnecting the NAS power for a few minutes, to make sure any bios state is cleared. If the NAS still has the same symptoms on power-up, you should look at the status with RAIDar ( https://kb.netgear.com/20684/ReadyNAS-Downloads ) and see if that shows a "no disks" status when the remaining drive is in slot 1. If if does, then the slot has likely failed.
What firmware is your NAS running?
Jun 11, 2018Guru - Experienced User
ironbut
Jun 19, 2018Aspirant
Thanks Stephen, I didn't check the previous version, but have upgraded the firmware on the offchance it would help, but no joy.
Looks like a new NAS is in order.
