EkDor
Apr 01, 2016Aspirant
Legacy unit with failed power supply. Looking to source replacement part
RND4000 (ReadyNAS NV+ v1 [v3] ) Legacy unit with failed power supply. Looking to source replacement part. Not after free replacement since it's obviously out of warranty and end of life product. Howe...
- Apr 01, 2016
Hello EkDor,
This PSU replacement was for free until supplies last and I heard that they already ran out of it.
RND4PSU1-10000S is the part number that you can look up in the Internet and see if there's any one selling online.Hope this helps.
Sandshark
Apr 03, 2016Sensei
Search the forum for "legacy power supply" and you will find your post, and this one:https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Inexpensive-power-supply-replacement-for-legacy-4-bay-Readynases/m-p/1016241#M13476
- EkDorApr 03, 2016Aspirant
Thanks SandShark. Looks like a good option. Cheers.
- mdgm-ntgrApr 04, 2016NETGEAR Employee Retired
Note that the NV+ v1 uses a different CPU architecture and RAID format to the NVX and Ultra 6 so you can't move your disks across to those.
There is however a process for using a current model ReadyNAS for data recovery. See ReadyNAS: Migrating disks from RAIDiator 4.1 or RAIDiator 5.3 to ReadyNAS OS 6
Once you've prepared the device for data recovery and contacted support and purchased a contract (if needed) support would provide you instructions on what to do next.Using a 3rd party PSU would be done at your own risk. It is not something we support.
- EkDorApr 04, 2016Aspirant
Thanks. I do understand that repeairs and replacement/mod PSU is all at own risk.
