TerryHarris
Jul 28, 2017Aspirant
Life after a DESTROY
Hi. Is there any comeback from a DESTROY. I've blown away a NAS thinking I had selecetd 2 drives and it appears it was the volume. It would make life easy if there was a way back rather than rebuild ...
- Jul 30, 2017
Hello TerryHarris,
There is no coming back from a DESTROY. If you will try to do it on the back end it may a be a long shot and may take a lot of work.
Welcome to the community!
Marty_M
NETGEAR Community Team
TerryHarris
Aug 02, 2017Aspirant
Hi. Thanks for the reply. I have recoevred the data. It would be excellent if the units had a simple "backup" proceedure just for the drive structure, logs, fat etc etc. I have reconstructed manually and restored the unit. Without the logs it would have been impossible (almost).
Aug 02, 2017Guru - Experienced User
You can back up and restore the config on the system->settings page.
