delange
Mar 28, 2013Tutor
LMS on latest ReadyNAS products?
Just found out about the new ReadyNAS product line. First question that came to mind is: is Logitech Media Server (LMS) still supported on this platform? I currently am very happy with my NVX but I ...
delange
May 26, 2013Tutor
vandermerwe wrote: Ok I don't understand. I've read a bit more, now I seem to understand that the wandboard would replace my squeezebox?
Is this correct?
The Wandboard (with the CSOS loaded) is a possible replacement for your Squeezebox. I say possible because the Wandboard with the CSOS (Community Squeeze Operating System) loaded is actually a Squeezebox like the Touch is. It can be a Squeezebox player and it can run LMS (the full version, not the tiny version that the Touch has). So the Wandboard is completely compatible with your current Squeezeboxes that you already have.
If your Touch dies you can replace it with a Wandboard. Or if you need an additional Squeezebox you can use the Wandboard too. And since the Wandboard is able to run LMS, you could use it when you upgrade your NAS to the new ReadyNAS generation.
