delange
Mar 28, 2013Tutor
LMS on latest ReadyNAS products?
Just found out about the new ReadyNAS product line. First question that came to mind is: is Logitech Media Server (LMS) still supported on this platform? I currently am very happy with my NVX but I ...
Shardstrat
Apr 10, 2014Aspirant
gregb-pro wrote: I built a test version of the Wandboard approach and it works well so far. It's a viable solution and frees you from LMS on ReadyNAS. [...] Performance is reasonable for a 5W computer; it handles a 25K track library and multiple SB classic and SB touch players. I'm looking for a 5-year solution that doesn't require LMS on a user desktop/laptop/workstation, and this is a contender.
Hi. I currently have a ReadyNAS NV+ and a Squeezebox Touch, with Logitech Media Server running on the NAS. It's much too slow. What kind of performance might I expect with the Wandboard approach? I have about 30k files, largely FLAC. To give you an idea, it takes up to 20 seconds or more for the Touch to read my Albums folder and start displaying the thumbnails.
Did you have any trouble getting the Squeezebox to recognize LMS on the Wandboard?
Another question: Do you think the Wandboard's audio performance will be better than the Squeezebox's? In other words, might it be better to eliminate the Squeezebox and fit the Wandboard with a small touchscreen?
TIA
