Sandshark
Feb 23, 2019Sensei
Local build of SMB plus for strict sync issue
In this thread: TrueCrypt-container, Skywalker provided access to a "local build" of SMB Plus to disable strick sysnc, which was creating issues with Truecrypt/Veracrypt containers. I installed it a...
Feb 23, 2019Guru - Experienced User
In 6.9.5 there is a "strict sync" setting for each share that (share settings->network access->smb->advanced).
- SandsharkFeb 25, 2019Sensei
Yes, but 'm pretty sure I need to make sure I turn off he global setting that's currently there due to the special version of SMB Plus before I upgrade to a version with the option per share.
- StephenBFeb 25, 2019Guru - Experienced User
Maybe edit the config files with ssh after the upgrade?
- SandsharkFeb 26, 2019Sensei
I don't see how that is going to change something that was previously done globally.
It appears that the fix simply adds strict sync = no to /etc/frontview/samba/smb.conf.overrides, so I'm going to uncheck the box, verify it removed that line, and remove the special version of SMB Plus. Then reboot, upgrade, and install the standard SMB Plus. I was hoping to get some confirmation this was the appropriate action.
