Nobber1066's avatar
Nobber1066
RBRE960 cant connect locally
For some reason I cant connect locally or via orbilogin.net or orbilogin.login  to my Router, I just get refused to connect
I can get in via the app
When I reboot the router i get access of for about 1 minute then it disconnects again
The only thing I changed was I blocked an IP address 192.168.1.85, But I have since managed to unblock it before the router disconnects but I still have the issue
Any idea what has happened to cause this please
Thanks
Nobber
  • Ok so it appears to be working again all ok, not totally convinced but this is what I did
    1. Blocked a specific IP that I could not recognise obvs NOT my PC
    2. After that the problem started, could not connect locally but could through the app
    3. connected via edge on my phone turned of Access control
    4. then was able to connect via my PC
    5. Turned access control back on then everything started working agin as it should
    Thanks for all the replies
    Nobber
  • plemans's avatar
    What modem do you have?
    Have you checked in the app to see what IP address the orbi router is using? Try connecting with that
    • Nobber1066's avatar
      Nobber1066
      Thanks for the reply, dont have a modem I'm using a BT Hub in bridge mode, internet is working fine
      the Router is 192.168.1.1
  • CrimpOn's avatar
    CrimpOn
    what happens when a web browser attempts to open 192.1681.1?
    windows for login credentials appears?
    credentials are (accepted? rejected?)
        Nobber1066
        Strange just connect via my phone through edge and connected ok
        I turned of access control and connected straight away through Chrome...tried edge again and it seems to be ok now, I'll try turning on access control to see if thats the problem
  • CrimpOn's avatar
    CrimpOn
    The device running the web browser is connected to the LAN side of the Orbi, correct?
    (either 'wired' or using the Orbi WiFi)
  • CrimpOn's avatar
    CrimpOn
    Tried both http and https for the web connection? (there is an optional setting on Orbi routers to allow only https connections)
    Nobber
    • FURRYe38's avatar
