Sandshark
Feb 23, 2019Sensei
Local build of SMB plus for strict sync issue
In this thread: TrueCrypt-container, Skywalker provided access to a "local build" of SMB Plus to disable strick sysnc, which was creating issues with Truecrypt/Veracrypt containers. I installed it a...
Sandshark
Feb 25, 2019Sensei
Yes, but 'm pretty sure I need to make sure I turn off he global setting that's currently there due to the special version of SMB Plus before I upgrade to a version with the option per share.
Feb 25, 2019Guru - Experienced User
Maybe edit the config files with ssh after the upgrade?
