therealnips
Jan 22, 2017Aspirant
Locked out of my ReadyNAS
I followed this guide to set up a website: http://kb.netgear.com/24829/ReadyNAS-OS-6-Create-a-personal-webserver and it worked fine, but now I cant access the admin login settings thing. I us...
lundmilo
Jan 22, 2017Luminary
therealnips wrote:I followed this guide to set up a website:
and it worked fine, but now I cant access the admin login settings thing. I used to use 192.168.1.65 or https://<NAS NAME> but now it just redirects to the index.html page in the website folder. How to I disable the website bit so I can have my NAS back to normal?
Thanks
I am not sure but shouldn't you be able to connect to the adminpage by udsing http://192.168.1.65/admin ?
- StephenBJan 22, 2017Guru - Experienced User
Yes, since he redirected http://192.168.65 to the web-server page.
Though https://192.168.1.65/admin would be better. I recommend disabling http access to the admin page if you are forwarding port 80 to the NAS.
- therealnipsFeb 07, 2017Aspirant
Thank you! I managed to get back in. If I disable the http log in (i assume to help prevent being hacked) how would I access the admin pages?
- JennCFeb 08, 2017NETGEAR Employee Retired
Hello therealnips,
Try adding "/admin" instead to get to the admin page.
Welcome to the community!
