therealnips
Jan 22, 2017Aspirant
Locked out of my ReadyNAS
I followed this guide to set up a website: http://kb.netgear.com/24829/ReadyNAS-OS-6-Create-a-personal-webserver and it worked fine, but now I cant access the admin login settings thing. I us...
lundmilo
Jan 22, 2017Luminary
therealnips wrote:I followed this guide to set up a website:
and it worked fine, but now I cant access the admin login settings thing. I used to use 192.168.1.65 or https://<NAS NAME> but now it just redirects to the index.html page in the website folder. How to I disable the website bit so I can have my NAS back to normal?
Thanks
I am not sure but shouldn't you be able to connect to the adminpage by udsing http://192.168.1.65/admin ?
Jan 22, 2017Guru - Experienced User
Yes, since he redirected http://192.168.65 to the web-server page.
Though https://192.168.1.65/admin would be better. I recommend disabling http access to the admin page if you are forwarding port 80 to the NAS.
- therealnipsFeb 07, 2017Aspirant
Thank you! I managed to get back in. If I disable the http log in (i assume to help prevent being hacked) how would I access the admin pages?
- JennCFeb 08, 2017NETGEAR Employee Retired
Hello therealnips,
Try adding "/admin" instead to get to the admin page.
Welcome to the community!
- mdgm-ntgrFeb 08, 2017NETGEAR Employee Retired
http admin uses port 80. https admin uses port 443.
So if you forward port 80, but not port 443, you'd have to be on the same LAN as the NAS and go to https://ip.address.of.nas/admin if http admin is disabled.
