therealnips
Jan 22, 2017Aspirant
Locked out of my ReadyNAS
I followed this guide to set up a website: http://kb.netgear.com/24829/ReadyNAS-OS-6-Create-a-personal-webserver and it worked fine, but now I cant access the admin login settings thing. I us...
Jan 22, 2017Guru - Experienced User
lundmilo wrote:
I am not sure but shouldn't you be able to connect to the adminpage by udsing http://192.168.1.65/admin ?
Yes, since he redirected http://192.168.65 to the web-server page.
Though https://192.168.1.65/admin would be better. I recommend disabling http access to the admin page if you are forwarding port 80 to the NAS.
therealnips
Feb 07, 2017Aspirant
Thank you! I managed to get back in. If I disable the http log in (i assume to help prevent being hacked) how would I access the admin pages?
- JennCFeb 08, 2017NETGEAR Employee Retired
Hello therealnips,
Try adding "/admin" instead to get to the admin page.
Welcome to the community!
- mdgm-ntgrFeb 08, 2017NETGEAR Employee Retired
http admin uses port 80. https admin uses port 443.
So if you forward port 80, but not port 443, you'd have to be on the same LAN as the NAS and go to https://ip.address.of.nas/admin if http admin is disabled.- StephenBFeb 09, 2017Guru - Experienced User
So if you forward port 80, but not port 443, you'd have to be on the same LAN as the NAS and go to https://ip.address.of.nas/admin if http admin is disabled.Yes. Which would be more secure.
