therealnips
Jan 22, 2017Aspirant
Locked out of my ReadyNAS
I followed this guide to set up a website: http://kb.netgear.com/24829/ReadyNAS-OS-6-Create-a-personal-webserver and it worked fine, but now I cant access the admin login settings thing. I us...
JennC
Feb 08, 2017NETGEAR Employee Retired
Hello therealnips,
Try adding "/admin" instead to get to the admin page.
Welcome to the community!
mdgm-ntgr
Feb 09, 2017NETGEAR Employee Retired
http admin uses port 80. https admin uses port 443.
So if you forward port 80, but not port 443, you'd have to be on the same LAN as the NAS and go to https://ip.address.of.nas/admin if http admin is disabled.
- StephenBFeb 09, 2017Guru - Experienced User
So if you forward port 80, but not port 443, you'd have to be on the same LAN as the NAS and go to https://ip.address.of.nas/admin if http admin is disabled.Yes. Which would be more secure.
- therealnipsFeb 10, 2017Aspirant
ive tried logging in from work using the NAS external ip address and it said it couldnt be found, so im guessing its ok...
