Alein's avatar
Alein
Looking for 12x HDD tray for ReadyNAS 4200 or ReadyData 5200
Hello, I am looking for HDD trays (12x) for ReadyNAS 4200 or ReadyData 5200. Where can I find/buy them? anyone know?
  • Sandshark's avatar
    Sandshark
    Mar 01, 2018
    The ReadyNAS 3200, 4200, and 4200V2 as well as the ReadyData 5200 are all SuperMicro units with specialized firmware.  Standard SuperMicro caddies are what you need, and they are available from several sources on eBay.  The ones I got were part number MCP-220-00075-0B, but I think MCP-220-00024-0B and MCP-220-00001-01 will work, too.  And if you will have any empty bays, you should fill those with caddies that have the plastic filler installed to maintain proper air flow.  A lot of sellers don't list the part number, so I've attached a picture.  The big thing is the smallish locking handle on the lower front.  The plastic filler only uses two screws, so you'll need more.  Those are avaialble on eBay, too, and on Amazon.  Make sure you get ones for 3.5" drives.
    If you need to use 2.5" drives, you'll need adapters or a different part number.
    Prices are all over the map, but you can usually make a deal for a large quantity.  I got a box of 36 for around $50 plus shipping.
ProSupport for Business
