kurokabau
Jul 28, 2015Aspirant
Lose connection to admin page of ReadyNas shortly after each reboot #25504479
Everytime I reboot my readynas I can access the admin page. 5 minutes later and im doomed to not be able to get on to it again until I reboot. I access it all through readycloud, its just the admin ...
Jul 28, 2015Guru - Experienced User
What model NAS and what firmware?
Do you have ssh enabled?
- kurokabauJul 28, 2015Aspirant
ReadyNas 104, 6.2.5.
I'm fairly sure I do.- vandermerweJul 28, 2015Master
How are you getting to the admin page?
Direct browser, through raidar, or through Readycloud?
What happens when you try to go to ipaddressofnas/admin?
Did this start with 6.2.5, or when did it start?
Any apps installed?
Antivirus on?
Direct browser, Raidar and Readycloud all just redirect me to ip/admin? https://192.168.0.2/admin/ They all open that url in my default browser (chrome). I can access all my files through readycloud.
This started before 6.2.5. Sometimes it will be fine for a fair amount of time, but then suddenly i wont be able to connect and this problem starts where the only posssibility is if i reset the device.
Apps installed are: Plex, Transmission and Sickbeard.
Antivirus used to be on, but recently turned it off to see if that helped. This problem was occuring before I did turn it off.
