houston1
Oct 26, 2015Aspirant
Losing internet connection constantly
Firmware 6.4.0 ReadyNAS RN2120-100NAS The scenario was that the volume was reporting near full but I was only using 1/8 of the available space. I found that it was the Snapshot feature for each...
BrianL2
Oct 26, 2015NETGEAR Employee Retired
Hi houston1,
Can you check the network settings for each network adapter? Also confirm (if both are active or in use) if you are using NIC teaming in your ReadyNAS while its in production. Sending thecurrent device logs will also help.
Kind regards,
BrianL
NETGEAR Community Team
- houston1Oct 27, 2015Aspirant
Thanks, Brian.
I just sent you the log files. Regarding your question: No, the nics are not teamed. Eth0 is configured to accept backups from specific devices on our network while Eth1 is networked directly to the partnered RN2120.
While testing today, I have noticed that the Eth0 LED is solid, but I can still connect. So I don't know what to make of the blinking or non-blinking of the LEDs.
- mdgm-ntgrOct 27, 2015NETGEAR Employee Retired
I can see you have SSH enabled and have been running rsync from the shell. Do you lose connectivity after starting rsync from the shell or is the loss of connectivity unrelated to that?
You still have some snapshots in the backend that weren't upgraded when you updated to 6.2.x. They don't show in the UI but they are there.The 2120 has a 5 year limited hardware warranty. You have not registered your unit yet. When did you purchase it? If your RN2120 was purchased on/after June 1, 2014 it would have lifetime chat support.
I have lost connectivity whether running RSYNC or not, but it does indeed lose connection during transfer. I specifically ordered these newer devices because of the newer RSYNC versions and issues with compaibility (While the other devices were aged and I feared failure at some point).
I'm not exactly sure how to view snapshots on the backend. Can you tell me what they might be called so that I can delete them through the terminal?
I ordered in the last 18 months. Let me check on that - that is very good news. Thank you!
Any ideas?
