houston1
Oct 26, 2015Aspirant
Losing internet connection constantly
Firmware 6.4.0 ReadyNAS RN2120-100NAS The scenario was that the volume was reporting near full but I was only using 1/8 of the available space. I found that it was the Snapshot feature for each...
BrianL2
Oct 26, 2015NETGEAR Employee Retired
Hi houston1,
Can you check the network settings for each network adapter? Also confirm (if both are active or in use) if you are using NIC teaming in your ReadyNAS while its in production. Sending thecurrent device logs will also help.
Kind regards,
BrianL
NETGEAR Community Team
houston1
Oct 27, 2015Aspirant
Thanks, Brian.
I just sent you the log files. Regarding your question: No, the nics are not teamed. Eth0 is configured to accept backups from specific devices on our network while Eth1 is networked directly to the partnered RN2120.
