RTSwiss
Jan 30, 2013Aspirant
loss of array after drive failure; problems with ST3500320AS
At the top, a modest complaint about the operation of the forum. I started a message several hours ago, and then got interrupted. To be on the safe side I copied the text out to notepad but left the...
Feb 03, 2013Guru - Experienced User
I think it would be hard to sort out what caused this w/o logs (and even then it might not be possible).
Did support tell you that they won't help because you are out-of-warranty? If not, maybe try submitting a request.
It is possible that the OS partition is full - so you might try to do an OS reinstall from the boot menu. That will reset your IP configuration to use DHCP and also reset your admin password to the factory default. Data and add-ons should be unaffected.
