DirkG
May 24, 2016Aspirant
Lost AD Connection after updating to 6.5.0 on Readynas 516 #26926627
Hello,
after updating my Readynas 516 from firmware 6.5.0-T338 to 6.5.0 final release, I am getting 'Failed to sync ADS account information for the realm' messages.
In the past, there was...
- May 27, 2016
DirkG, please don't run beta 6.5.0 firmware anymore. We are very limited in what we can do to help if you stay on that here and support won't be able to help with that firmware. Please update back to the 6.5.0 production release and open a support case, attach your logs to that case and let us know the case number. Thanks.
When users encounter this issue and do things to try to fix it themselves we lose the ability to get information that would help with identifying the root cause of the issue (so it's much harder to try to find a common cause that could lead to a fix in a future firmware release if that's needed).
JennC
May 25, 2016NETGEAR Employee Retired
Hello DirkG,
What is the OS of the computer that you are using to access the folders/shares? Are you able to access these shares when the authentication is set to local users?
These shares by the way should be set to Everyone and the share permissions should be set by DC.
DirkG
May 26, 2016Aspirant
Hello JennC,
I am using systems running Windows 10 Pro, Windows 2008 R2 Server and Windows 2012 R2 Server to access the folders/shares.
With all systems, I am having the same problems.
From my point of view, the problem is related with the error message that the Readynas is not able to import the AD accounts since the update to the final version of 6.5.0. Therefore, ist seems that the users couldn't be authentificated via the Readynas.
Moreover, I am not able to set any permissions for the AD user folders, which are automatically created by the Readynas:
- Via the administrative web page, there is no possibility to define any acces rights, if the folders belong to AD users
- Via SMB, I am not able to connect to this folder, because the access is denied (Unable to import AD accounts...)
Please also have in mind that once the AD account caching is disabled (direct query of the accounts to to DC), the problem disappears and there was no problem at all with all other OS versions of the Readynas 516 before.
Therefore, it is not a problem of the share permissions, but with the security handling of AD accounts within the Readynas.
Best regards
Dirk
