ibell63
Jun 26, 2017Aspirant
Lost another volume
On firmware 6.7.4 ran a scrub before leaving for the weekend on Friday, came back in today after not having received a notification that the scrub had ever finished, couldn't make any changes to the ...
- Jun 26, 2017
Hi again,
Yes, so there is definitely some corruption on the filesystem - unfortunately. You can probably see that yourself reading through some of those messages. It would cause issues mounting the volume and thus you see no wolume anymore. This is not a result of the scrub by the way.
It is one of the problems with running a RAID0. You are much more prone to these sort of problems as there is no fault tolerance at all. If any of the disks were stalling or if there are errors on any of the disks it can cause serious issues for a RAID0. Are all the disks OK? You can check it in the disk_info.log
Do you have have a backup of the data? If so, you are best to factory default and restore from backups. Also, you might want to consider whether RAID0 is the correct RAID for your setup? It is rather risky on 4 drives I think.
Hopchen
Jun 26, 2017Prodigy
Hi,
First thing is to check whether the data RAID is running. Can you please post the mdstat.log ?
Thanks
ibell63
mdstat.log
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid0 sda3[0] sdd3[3] sdc3[2] sdb3[1]
23422691328 blocks super 1.2 64k chunks
md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1]
1046528 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Mon Oct 10 14:44:16 2016
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Mon Jun 26 12:53:42 2017
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Name : 117c606a:0 (local to host 117c606a)
UUID : 1d244df2:605bbba2:95ce8d48:297bec93
Events : 86
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
2 8 33 2 active sync /dev/sdc1
3 8 49 3 active sync /dev/sdd1
/dev/md/1:
Version : 1.2
Creation Time : Mon May 15 18:47:04 2017
Raid Level : raid10
Array Size : 1046528 (1022.00 MiB 1071.64 MB)
Used Dev Size : 523264 (511.00 MiB 535.82 MB)
Raid Devices : 4
Total Devices : 4
Update Time : Mon Jun 26 10:41:10 2017
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : near=2
Chunk Size : 512K
Name : 117c606a:1 (local to host 117c606a)
UUID : 7eb71118:4e648fc4:7b53a41b:99cd94fa
Events : 19
0 8 2 0 active sync set-A /dev/sda2
1 8 18 1 active sync set-B /dev/sdb2
2 8 34 2 active sync set-A /dev/sdc2
3 8 50 3 active sync set-B /dev/sdd2
/dev/md/data-0:
Version : 1.2
Raid Level : raid0
Array Size : 23422691328 (22337.62 GiB 23984.84 GB)
Raid Devices : 4
Total Devices : 4
Update Time : Mon May 15 18:47:04 2017
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Name : 117c606a:data-0 (local to host 117c606a)
UUID : 7abc2a8b:b6a7cb06:e80da4b0:8c8d78e6
Events : 0
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3Related Content
