ibell63
Jun 26, 2017Aspirant
Lost another volume
On firmware 6.7.4 ran a scrub before leaving for the weekend on Friday, came back in today after not having received a notification that the scrub had ever finished, couldn't make any changes to the ...
- Jun 26, 2017
Hi again,
Yes, so there is definitely some corruption on the filesystem - unfortunately. You can probably see that yourself reading through some of those messages. It would cause issues mounting the volume and thus you see no wolume anymore. This is not a result of the scrub by the way.
It is one of the problems with running a RAID0. You are much more prone to these sort of problems as there is no fault tolerance at all. If any of the disks were stalling or if there are errors on any of the disks it can cause serious issues for a RAID0. Are all the disks OK? You can check it in the disk_info.log
Do you have have a backup of the data? If so, you are best to factory default and restore from backups. Also, you might want to consider whether RAID0 is the correct RAID for your setup? It is rather risky on 4 drives I think.
ibell63
Couldn't post the output of that command because it's too long, so I uploaded it to pastebin:
https://pastebin.com/26WTbCLC
Hopchen
Jun 26, 2017Prodigy
Hi again,
- ibell63Jun 26, 2017Aspirant
The data is not unique and I have backups I can restore from. I'll reformat as XRAID. disk_info.log does not show any issues. Here it is below for your reference, also:
Device: sda Controller: 0 Channel: 0 Model: WL6000GSA12872E Serial: WOL240343186 Firmware: 01.01C01 Class: SATA Sectors: 11721532032 Pool: data PoolType: RAID 0 PoolState: 5 PoolHostId: 117c606a Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 36 Start/Stop Count: 184 Power-On Hours: 8504 Power Cycle Count: 133 Load Cycle Count: 153 Device: sdb Controller: 0 Channel: 1 Model: WL6000GSA6472E Serial: WOL240336490 Firmware: 01.0RRE2 Class: SATA RPM: 5700 Sectors: 11721045168 Pool: data PoolType: RAID 0 PoolState: 5 PoolHostId: 117c606a Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 39 Start/Stop Count: 227 Power-On Hours: 8890 Power Cycle Count: 140 Load Cycle Count: 187 Device: sdc Controller: 0 Channel: 2 Model: WL6000GSA6472E Serial: WOL240336488 Firmware: 01.0RRE2 Class: SATA RPM: 5700 Sectors: 11721045168 Pool: data PoolType: RAID 0 PoolState: 5 PoolHostId: 117c606a Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 39 Start/Stop Count: 213 Power-On Hours: 8737 Power Cycle Count: 136 Load Cycle Count: 175 Device: sdd Controller: 0 Channel: 3 Model: WL6000GSA6472E Serial: WOL240336487 Firmware: 01.0RRE2 Class: SATA RPM: 5700 Sectors: 11721045168 Pool: data PoolType: RAID 0 PoolState: 5 PoolHostId: 117c606a Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 36 Start/Stop Count: 221 Power-On Hours: 8826 Power Cycle Count: 139 Load Cycle Count: 178
- HopchenJun 26, 2017Prodigy
Yes, your disks seems fine here. But a RAID0 is so intolerant that any hicpus can be problematic - the more disks involved the bigger the risk. It is hard to say exactly what caused it. The point is that there is no recovery for the filesystem once it encouters errors - as there is no redundancy.
I am glad you had a backup and that you are considering a RAID with some redundancy.Just as an FYI - things that can typically lead to filesystem corruption is:
1. Disk issues.
2. Filling the filesystem too much. You should leave about 10% free space.
3. Non-graceful shutdowns (such as power-cuts).
Best of luck!- ibell63Jun 26, 2017Aspirant
ReclaiME finds my filesystem and it appears that it will be able to recover data from it.
