Jellen
Jul 24, 2020Aspirant
Lost volume after migration from RN314 to RN3138
Hi
I wanted to migrate my data and volume from a Readynas RN314 to a new rackmount RN3138.
Shut down both units, transferred the drives and kept the same drive order.
After boot I was able to login using my current account. But the volume doesn't show up.
I receive an error message to remove inactive volumes to use the disk #1,2,3
All help is welcome :-)
Kind regards
Jellen
Hi Jellen,
This should be fixed now. Please check if you can now access your volume.
The OS was filled up so one of our L3 experts cleaned it. The problem could be the Docker because he saw that installed.
- JohnCM_SNETGEAR Employee Retired
Hi Jellen,
Do you have a backup of your data?
Can you also download the logs the send it to me via private message? We will check what caused the issue. You may upload the logs to a file-sharing site then send me the download link.
- SandsharkSensei
You didn't say you did, but I just want to verify that you did NOT export the volume (you shouldn't have).
Have you tried putting the drives back in the 314 and seeing what happens? Assuming the three drives you listed are all there is, you could try every combination of two and see if it'll boot with a degraded volume.
- JellenAspirant
Hi Sandshark
No I din't export the volume. John is looking into the logs but looks like my volume has 2 devices. I'll keep you guys up to date.
Strange thing on the device my 3X 8TB Seagete disks show the Hard disk light continuos on, the one WD 3TB drive flickers. It's all one volume.
Thanks for the replies, keeping fingers crossed to recover the volume.
