stevenestrada
Jan 22, 2018Aspirant
LUN keeps disconnecting
I have one lun in a volume by itself taking up half its space, mapped to a windows 2008 server used as a wsus content drive sync write disabled, no security execpt for the allow iqn list of one, man...
mdgm-ntgr
Jan 22, 2018NETGEAR Employee Retired
Which firmware did you update to 6.9.1 from (you can see this in initrd.log)?
Any other issues?
stevenestrada
Mar 18, 2018Aspirant
Ugraded from 6.9.0
Root volume filling up two months later in 6.9.3
- StephenBMar 19, 2018Guru - Experienced User
stevenestrada wrote:
Ugraded from 6.9.0
Root volume filling up two months later in 6.9.3Do you mean the OS partition on the NAS or the data volume?
If you mean the OS partition, then what apps do you have installed? Do you have the AntiVirus service enabled?
- stevenestradaMar 19, 2018AspirantFile search and av disabled Experimenting with the windows server nic acks got the lun to stay up, albeit with some windows events I got two utilities + smpplus installed, or did until 6.9.3 resulted the root partition getting bigger by the minute. Now its just smpplus. But that's a separate issue
