h4lt3r's avatar
h4lt3r
MacOS printing problem
Hi!
I have a strange problem with printing through NetgearNV+ (4.1.8). My LaserJet M1132 is connected via usb and the system recognises it normally:
========dmesg=========
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 3
usb-storage: waiting for device to settle before scanning
chn=1, statu/LP_S=0x(d0/d050)29, 16
Vendor: HP Model: Smart Install Rev: 1.0
Type: CD-ROM ANSI SCSI revision: 02
usb-storage: device scan complete
:<6>usb 1-1: USB disconnect, address 3
:::::<6>usb 1-1: new high speed USB device using ehci_hcd and address 4
usb 1-1: configuration #1 chosen from 1 choice
scsi1 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 4
usb 1-1: USB disconnect, address 4
usb 1-1: new high speed USB device using ehci_hcd and address 5
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 5 if 0 alt 0 proto 2 vid 0x03F0 pid 0x042A
USB: Hewlett-Packard HP LaserJet Professional M1132 MFP printer connect.
After that i can see the printer via http on storage:631/printers url. I connect the printer to my xp laptop and it works quite acceptable (i can print the test page), but i see this errors in /var/log/cups/error_log file:
========error_log=========
storage:/var/log/cups# tail error_log
E [28/May/2012:17:39:15 +0500] get_printer_attrs: resource name '/HP_LaserJet_' no good!
E [28/May/2012:17:39:17 +0500] get_printer_attrs: resource name '/HP_LaserJet_' no good!
E [28/May/2012:17:39:27 +0500] get_printer_attrs: resource name '/HP_LaserJet_' no good!
E [28/May/2012:17:39:37 +0500] get_printer_attrs: resource name '/HP_LaserJet_' no good!
The problems began when i tried to connect the printer to my macbook (10.6.8) - when i'm trying to connect the printer using IPP (bonjour on NV+ is turned on):
1) when i'm trying to connect just by specifying ipp and "storage" as address i got this in logs:
E [28/May/2012:17:48:40 +0500] get_printer_attrs: resource name '/' no good!
2) when i specify the port 631 in queue i got this:
E [28/May/2012:17:52:12 +0500] Bad request line ""!
3) when i specify the address, port and queue (http://storage:631/printers/HP_LaserJet_) i
E [28/May/2012:17:56:08 +0500] Bad request line "http://storage:631/printers/HP_LaserJet_"!
but the strange thing i noticed - in line "est line "http://storage:63" i see a space between " and http (and also in previous error " Bad in request line """ - between "'s ), but when i copy-pasted it here - this symbol disappears.
4)when i specify the address, port and queue without "http://", i just got this error:
E [28/May/2012:18:01:36 +0500] get_printer_attrs: resource name '/storage:631/printers/HP_LaserJet_' no good!
and the error message is now without any weird symbols - mac tells me "couldn't open fifo (22)" and then just pauses printing - in all cases. I'm not sure, that the "no good" error from error_log is the problem case, but it's the only error i could find in logs. Any ideas, where to look or what to do?
  • And btw, i print normally on the same printer, when i connect it directly to macbook via usb cable, so that means, i think, that it's not a drivers problem...
  • Use the way like you access a Printer wich is connected to a windows server - somewhere with SMB:// - I forgot the details, but its easy to find if you know what to do.
    The Network-printing thingie is somehow broken in Lion if you try to use it over AFP or netprint/IPP.
    Its not a Problem with the NAS, because before I upgraded SnowLeo to Lion it was OK, and now I use Windows-Printer-access too.
ProSupport for Business
