Khobayachi
Mar 19, 2018Aspirant
Management service is offline (ReadyNas Ultra 6 / FW 6.9.1)
Hi, Since a few hours my readynas (Ultra 6) LCD screen shows "Retry Startup". After a few unsuccessfully access to the admin page & reboot attempts, I checked RAIdar (6.3-T1) that confirmed Manageme...
- Mar 25, 2018
Solved thanks to mdgm :
1. OS Reinstall finally gave me access to the management service
2. After SSH activation I found and deleted the big file that was filling the root volume :
# mount --bind / /mnt # du -csh /mnt/*
Thanks mdgm for your time and the few tips.
mdgm-ntgr
Mar 19, 2018NETGEAR Employee Retired
USB Boot Recovery involves using the backup button, so if that's not working you might struggle to try to use that.
USB Boot Recovery is probably not the answer here. It won't solve a full root volume.
- KhobayachiMar 19, 2018Aspirant
Hi mdgm,
Wasn’t expecting a good news but this one freaks me out (no backup).
will I take any risk if I try the USB Recovery OS reinstall (without doing anything if I can’t switch menu options) ?
thanks again
- KhobayachiMar 25, 2018Aspirant
- Jun 10, 2022Retired_Member
