icuit
Feb 25, 2016Aspirant
Management service is offline
Hi. We have a problem whereby we can't access the Admin page, just says ReadyNAS Admin Page is offline. Within Raidar the status is "Management Service is offline". No firmware update has been app...
- Feb 26, 2016
No, it's not meant to be empty but that doesn't matter too much as i want to set the NAS up again from scratch. No i don't have a backup of the data but i don't need a backup.
Thanks
icuit
I'm not sure if this helps but i have found this in the logs:
Feb 25 15:13:55 *********** readynasd[4501]: readynasd log started
Feb 25 15:13:55 *********** readynasd[4501]: readynasd started. (restarted=0)
Feb 25 15:14:15 *********** readynasd[4501]: Error create table (db)
Feb 25 15:14:15 *********** readynasd[4501]: dba create failed
Feb 25 15:15:35 *********** readynasd[4501]: Error create table (db)
Feb 25 15:15:35 *********** readynasd[4501]: dba create failed
Feb 25 15:15:35 *********** readynasd[4501]: Initialization failed. We don't want to keep retrying. Only twice.
Thanks
JennC
Feb 25, 2016NETGEAR Employee Retired
Hello icuit,
Welcome to the community!
I suggest you call support asap. You may also really need to get to where the NAS is as it may need a reboot and you need to put it on telnet mode for remote access of support.
- Jun 10, 2022Retired_Member
