icuit
Feb 25, 2016Aspirant
Management service is offline
Hi. We have a problem whereby we can't access the Admin page, just says ReadyNAS Admin Page is offline. Within Raidar the status is "Management Service is offline". No firmware update has been app...
- Feb 26, 2016
No, it's not meant to be empty but that doesn't matter too much as i want to set the NAS up again from scratch. No i don't have a backup of the data but i don't need a backup.
Thanks
mdgm-ntgr
Feb 25, 2016NETGEAR Employee Retired
I assume you downloaded the logs zip file using RAIDar?
You should have that zip file ready to provide to support. You can send your logs in if you like (see the Sending Logs link in my sig)
icuit
Feb 26, 2016Aspirant
mdgm,
Thank you for your reply. Yes i did use RAIDar to download the logs; i will forward these on shortly. I am happy to Factory Reset if necessary but would prefer any other option which i could action remotely.
Thanks for your help.
icuit
- mdgm-ntgrFeb 26, 2016NETGEAR Employee Retired
Thanks for the logs.
Yes, you have encountered the snapshot upgrade issue.
Is the Backup share meant to be empty?
Do you have a backup of your data?- icuitFeb 26, 2016Aspirant
Thanks
- JennCFeb 26, 2016NETGEAR Employee Retired
Hello icuit,
If you do not have important data stored to the disks then best thing to do is factory reset from the boot menu. Disks that you want to use with the NAS should be all inserted when you do the factory reset so the volume will be created out from these disks.
Looking at your logs it would be best if you opened a support case as JennC suggested if you need a data recovery attempt. Support would need to charge for this.
- Jun 10, 2022Retired_Member
