MTUser2013
Mar 10, 2018Tutor
Many Duplicates for shared resource shown on player devices
I store copies of the DVDs that I own my NAS in the Media folder. On some playing devices, I see many copies of the same file. When I look at the folder on my Mac or Windows machines, I only find one copy of the file. If I delete from the Media folder, the player shows one less copy but all the other icons for the file are still there. If I click on play when I've deleted the file, the player tries to play all the versions of the file it sees, then plays the next video in alphabetical series. If I add back the file to the ReadyNAS media folder, I just get one more file icon in the folder.
This strange icon duplication problem is driving me crazy. I hope someone has had this same problem and knows how to fix it!
Go into the web ui (system->settings->services). Select ReadyDLNA, and click the Rescan button. After the Rescan completes, the duplicates should disappear.
Please do post back, and let us know if the rescan takes care of it.
Are these devices using DLNA?
Thanks for the reply. Yes, I think the duplicates show up on DLNA devices. I am using a LG Blueray Network Player, BPM35. Are these duplicates some kind of cache from the player? Can you get rid of them?
- Nov 04, 2020Retired_Member
