Spiv30
Dec 08, 2013Aspirant
Mavericks: file to large
Hi, I just bought a RN102 model but I have this error which is major to me when I try to move a large file (> 4Go) on the NAS : The item “...” can’t be copied because it is too large for the vol...
mdgm-ntgr
Dec 08, 2013NETGEAR Employee Retired
If you backup your data and do a factory default (wipes all data, settings, everything) does that resolve the issue?
I always recommend that when installing a new system you update to the latest firmware, verify the update completed successfully then do a factory default to get a clean setup on the latest firmware.
