tcc1
Jul 11, 2013Aspirant
Max disk size for NVX
Hello All, I just discovered that one of my disks crapped out (weird that it didn't email me since my alerts are functioning properly) in my NVX. I'm not sure if there are two versions of this uni...
tcc1
Jul 12, 2013Aspirant
That's what I thought hence the rambling :D
I do have a backup of the important files of the system via a NV+ so that should be ok.
I don't know what I was thinking earlier but my plan is to replace the failed 1TB drive with another one, let the system rebuild itself and then replace the other two 500GB drives with 2TB drives one at a time. Hopefully everything will turn out ok.
Should I do a reboot of the system after all the new drives have been installed and rebuilt?
