tcc1
Jul 11, 2013Aspirant
Max disk size for NVX
Hello All, I just discovered that one of my disks crapped out (weird that it didn't email me since my alerts are functioning properly) in my NVX. I'm not sure if there are two versions of this uni...
Jul 13, 2013Guru - Experienced User
It would do no harm, and it is nice to confirm that it does start up normally.
tcc wrote: Should I do a reboot of the system after all the new drives have been installed and rebuilt?
You'll likely need to reboot at least once, and maybe twice during the expansion process. Your approach will expand twice, once after each 500 GB replacement.
