wagb4
Sep 08, 2014Aspirant
Media Applications Recommendations
I seek opinions, recommendations, etc. from users with experience with the applications avaiable for my new RN102 as to which I should use for sending Photos and maybe music and videos from the NAS to...
Sep 15, 2014Guru - Experienced User
It certainly has the horsepower, as I mentioned my RN102 is serving similar stuff. For instance.
Do you have any other devices you can try? Preferably a windows or mac OS? Codecs advertised in the browser is most likely the problem. I think H.264 requires you to use the gstreamer codecs in linux versions of FireFox.
General
Complete name : xxx
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 323 MiB
Duration : 42mn 29s
Overall bit rate mode : Variable
Overall bit rate : 1 063 Kbps
Collection : xxx
Season : 1
Part : 7
Encoded date : UTC 2014-01-06 17:21:37
Tagged date : UTC 2014-01-06 17:21:37
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 42mn 29s
Bit rate : 933 Kbps
Maximum bit rate : 6 867 Kbps
Width : 720 pixels
Height : 404 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.134
Stream size : 283 MiB (88%)
Writing library : x264 core 140 r2377 1ca7bb9
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2014-01-06 17:00:59
Tagged date : UTC 2014-01-06 17:21:39
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 42mn 29s
Bit rate mode : Variable
Bit rate : 126 Kbps
Maximum bit rate : 160 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 38.4 MiB (12%)
Encoded date : UTC 2014-01-06 17:21:38
