ronaldvr2132
Dec 14, 2019Apprentice
Message volume encountered an error and was made read-only. It is recommended to backup your data.
I get the above message on my RB628X which is already my back-up NAS. This back-up NAS is on a remote location where no one is and no one is using the NAS as well. This particular RN628X is not doing anything other then once per day receive incremental back-ups from my other RN628X NAS. What can I do here? The NAS is still accesible and I see that the volume is read-only and that the space allocated to snapshots is 0 which is not correct.
What I did do a few weeks/months before this error message is that I canceled a disk scrub a few weeks or months before this date as it was already running for more then 10 days and it was consuming a lot of resources on the NAS. This isssue is related to the fact that doing a disk scrub results in doing two taks at the same time which influence eacht other I found out. This issue of the Diskscrub is already reported a long time ago and it would be nice if Netgear fixes this bug as soon as possible! But for now what can I do the best? I am using ReadyNAS devices already from the Infrant time, but since I am using the RN628X's I have had a lot of issues that should not occur.
Download the log zip file, and look for btrfs errors in system.log and kernel.log. More than likely you will find them.
Also look for disk errors in those logs, and at the SMART stats in disk_info.log. OS-6 has quite high thresholds for reallocated and pending sectors - much higher than what I generally use. So it is possible that a disk is failing despite the green status.
If the disks are healthy, but the volume has BTRFS corruption, then the best thing to do is a factory default, reconfigure the NAS, and start over on the backups. I realize this is painful (and will take a long time over the internet).
Overall - is the remote NAS protected by a UPS? Volume corruption can result if the NAS is unexpectedly shut down, due to lost writes that are still cached.
- ronaldvr2132Apprentice
Hi StephenB thank you for the reply. I looked in the disk logs and don't see something strange. All the disks seems to be healty.
Furthemore I looked for BTRFS corruption and found the following messages:
Kernel log:
kernel: BTRFS error (device dm-0): parent transid verify failed on 25195445682176 wanted 686858 found 675093
System log:
delete snapshot failed, ioctl(BTRFS_IOC_SNAP_DESTROY) failed, errno:30 (Read-only file system)
The system is on a UPS and is for 1 hour per day receiving data. The logs go only back 2 days and the erroro message about the volume occured on November 30th at the time that the back up was send over from my main RN628X to this back-up one. There was no power failure and the disks are oke. This is what I see in the Logs on the webui:
Nov 30, 2019 12:38:57 AM (yellow round) Volume: The volume XXXXX encountered an error and was made read-only. It is recommended to backup your data.
This RN628X has been exchanged with a new one because of my old one got bricked when it got stuck (unexplained why) during a firmware update. Other then this this is a NAS that is only used for back-up purposes and is behind a UPS. During the time that this error occured I can't think of any reason why the volume gor corrupted. Rebuilding the NAS would be a big frustration for me to be honest as sending over the data via internet would take a very long time. Hope we can stay away from this.
Kernel log:
I think the best way to deal with this is to rebuild the NAS. One reason is the dm-0 is the OS partition, not the data volume.
Paid support might be able to fix it remotely though - since you have access to the web ui, you should be able to enable the diagnostic mode.
