EHCanadian
Mar 03, 2020Star
Micro USB UART Hardware
I am trying to interface with the micro usb uart and not having any luck. I have tried with a micro usb USB to serial chip CH340 (Driver installed) https://cdn.sparkfun.com/datasheets/Dev/Arduin...
Marc_V
Mar 05, 2020NETGEAR Employee Retired
Any Micro USB cable should do. Have you tried using this driver used on a managed switch? Please click here.
HTH
Regards
- EHCanadianMar 05, 2020Star
I have added the driver that you have linked to.
Silicon Labs CP210x USB to UART Bridge is present.
Now to figure out the port settings to communicate.
- Marc_VMar 08, 2020NETGEAR Employee Retired
Can you try to use the following settings?
Speed 9600
Data bits 8
Stop bits 1
Parity None
Flow control XON/XOFF
HTH
- schumakuMar 09, 2020Guru - Experienced User
EHCanadian wrote:Silicon Labs CP210x USB to UART Bridge is present.
You have to find the virtual COM port on the Windows system - however, both PuTTY and Hyperterminal should "see" it.
