fnolden
Nov 22, 2021Aspirant
Hardware Replacement
I am trying to register for a harware replacement, but get a "somethingWentWrong" error when doin gthe registration. There is no option to mail/call support if I do not have a registered call and this is what fails. So I am in a deadlock. My problem is as follows:
My switch does not transfer traffic anymore. The loop test works fine and when connecting a network cable to 2 consecutive ports both lights at both ends light up. However, the switch does not pass any traffic anymore.
I have tested this with multiple cables, tested the cables themselves as well, used various laptop and desktop systems but nothing works.
The 100M light of the connected computer turns on solid green after a period or blinks now and then, but the lights at the cable connected to my router are dark. Even when I use other ports on the switch. The system receives a self-assigned IP address due to the fact that it cannot find my DHCP server.
How do I register a call? Can anyone help me who has had the same problem?
Welcome to the community! :)
Based on your initial post, you have indicated a GS116v1 switch. Let us try this. Go the support page of the GS116v1 switch here and click the "Guided Assistance" button and follow the online instructions to create a support ticket. Be ready to submit a soft copy of the Proof of Purchase of your switch for warranty verification. If the hardware warranty is still valid, an online replacement will be processed.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
DaneA
- fnoldenAspirant
DaneA this helped and routed me to a local phone number. Thanks a lot...
That's great! I'm glad that it helped you. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
