pgjscottieuk
Nov 23, 2017Guide
Migrate a volume os6 readynas 316 to 516
I am currently running a 516 poppulated with 6 wd 4tb drives in raid 6 i have a backup nas 316 poppulated with 6 seagate iron wolf pro 10tb running same up to date firmware. I want to expand the 516...
- Nov 23, 2017
Whether the 516 gets the same IP depends on how it is assigned. If it is assigned by DHCP reservation, then it will stay the same, as it will follow the MAC address. If it is staticly assigned by the NAS, then it will follow the drives until you change it.
Nov 23, 2017Guru - Experienced User
You can migrate disks between OS 6 NAS - so that will work. (BTW you can migrate between X86 and ARM OS 6 NAS too, but that can create trouble with platform-specific apps).
It's best to make sure they are running the same firmware version first.
pgjscottieuk
Nov 23, 2017Guide
Both NASA’s are running the same firmware the 516 main Nas also has the Plex server both Nas have identical shares Films and Music would the Plex data have been saved on the 316 the backup job hence when I remove those drives iron wolf pro 10tb and swap them into the 516 will that info be there and what else will I need to do
- StephenBNov 23, 2017Guru - Experienced User
Everything is on the drives - the OS boots from the drives, though it is in it's own partition that is not normally accessible over the network. Apps you have installed on the RN316 will migrate to the RN516 with the drives. Apps that are on the RN516 will need to be reinstalled after you migrate the disks. And since you plan to do a fresh install to create the new volume with 10 TB drives, such apps will need to be reinstalled anyway after you have the new volume up and running. You can of course do that after you migrate the new volume back to the RN516.
In the specific case of plex, the bulk of the software (and the media libraries) are in a hidden folder on the data volume (data/.apps/plexmediaserver)
The general process I recommend with the new drives is to do a factory reset with all drives in place. Then reconfigure the NAS (set up users and shares, reinstall apps), and then copy back the data using rsync backup jobs for the shares. If you use the home folders, it might be easier to drag/drop (the backup jobs don't work that well for the home folders).
If you plan to re-apply a saved config file, then I do recommend that you install the original apps first (or uninstall those apps before you save the config). They do reference the apps folder, and if the apps are not installed that can create some issues. Also, the NAS doesn't reapply all the settings, so you do need to review everything. For instance, I don't believe the volume maintenance schedule is re-applied.
- pgjscottieukNov 23, 2017Guide
I have no apps installed on the backup drive (316) it is purely a backup of the 516
i had originally thought if i migrated the disks from the 316 to the 516 all the information would be there and it wouldn’t change the settings etc on the main drive (516) the ip address etc would remain in tact so that things like my HTPC that are mapped to it wouldnt be disturbed
if that is not the case i may as well buy a 626x as the 628 isnt compatilbe with Plex temporarley take the 516 out of the system unplug it along with lan connection set up the new 626x configure it the same host name ip addresses etc enable the Plex server having signed out from the 516 then restore it with the media files from the 316 decomission that and teplace it with the 516 migrating the drives from the 316 iron wolf pro 10tb
i would really like to populate the new 626 with WD Red Pro 10TB just waiting for them to be approved
- SandsharkNov 23, 2017Sensei
