ablock
Sep 10, 2014Aspirant
Migrating disks from RND4000 to another RND4000 -- safe?
Hello all. I've had an RND4000 NV+ since Infrant days. It has worked well but a few month ago the chassis failed. When you press the power button, the drive lights flash briefly but nothing happens...
Marto731
Ablock,
For your info, there are previous posts re the NV+ v1 power supply.
http://www.readynas.com/forum/viewtopic.php?f=24&t=65944
Thoughts:
Plan A : When the 2nd chassis comes, insert a blank disk, and bring to what you judge was the same f/ware as first.
Power off, and move 4 disks across, keeping left to right order. You may need to OS re-install after.
Plan B is to move PSU from 2nd unit to first. This may pin issue to down motherboard or PSU.
Regards, Marto
Thoughts:
Regards, Marto
