PilotSteveB
Oct 25, 2013Aspirant
Migrating from X-RAID2 single redundancy to Dual redundancy
Hello, I have a ReadyNAS Pro Pioneer with 6 2TD disks in X-RAID2 single redundancy running on firmware ver 4.2.24. I'm only using 45% of the total space. Is is possible to migrate from single redu...
mdgm-ntgr
Oct 25, 2013NETGEAR Employee Retired
If you last did a factory default on very old firmware (your sig still shows 4.2.8 as the firmware running on your Pioneer) there would be some other nice benefits from a factory default.
These benefits would include: Native EXT4, 4k sector partition alignment of all disks (regardless of whether you installed them before/after upgrading to 4.2.12+), support for files >2TB in size etc.
