PilotSteveB
Oct 25, 2013Aspirant
Migrating from X-RAID2 single redundancy to Dual redundancy
Hello, I have a ReadyNAS Pro Pioneer with 6 2TD disks in X-RAID2 single redundancy running on firmware ver 4.2.24. I'm only using 45% of the total space. Is is possible to migrate from single redu...
mdgm-ntgr
Nov 22, 2013NETGEAR Employee Retired
This option might only be there if you have a single layer. Since you've already had some vertical expansion (adding two or more 2TB disks) you definitely have more than one layer.
A backup and a factory default (wipes all data, settings, everything) would be the way to go for you too.
