AdrianM
Mar 29, 2016Tutor
Migrating ReadyNAS Duo to RN102
It's been a while. Sigh. So, my trusty old sparc box needed an update - it's still going strong but is just too slow by today's standards so I bought a RN10200 and a couple of Seagate 2Tb (yes I'm on...
- Mar 30, 2016
It's a bit faster to reorganize on the duo, and then do share-by-share backup to the RN102. Shares are subvolumes on the RN102, so moves between shares become copy/deletes. Also if snapshots are enabled, they also can start taking up space.
So maybe create the folders on the duo that you ultimately want, then access the duo's C volume (\\nasip\C with NAS admin credentials), and shuffle the files around. Then use share-by-share backups to get them onto the RN102. Drag/drop works, but all the data is copied through the PC.
