giosheringam
May 04, 2017Aspirant
Migrating TimeMachine Sparsebundle from LACIE to ReadyNas102
Hello all I have a Lacie NAS with my TimeMachine backup in it. The sparsebundle is nearly 1TB. I would like to move it to a private TimeMachine in my ReadyNas 102. I would like to do as follow, and ...
- May 04, 2017
It is probably easier to add the ReadyNAS Time Machine as an additional backup source on the Mac, and let it do a full sync. The Mac Time Machine client has supported multiple backup destinations for a while now - OS X Yosemite: Use multiple backup disks - Apple Support
Once completed, you can remove the LaCie Backup destination from the Time Machine client.
itsjasper
May 04, 2017Luminary
giosheringam
Thanks! I didn't know about multiple backups.
This solution is much esier. I'll keep the two backups and eventually remove the Lacie when needed.
