espie
Mar 15, 2016Guide
Minidlna not responding ?
Most current OS, minidlnad -V says version 1.1.5. I'm currently transfering a lot of video files. This yields several issues. - my client "loses" minidlna connection completely if I leave it idle...
kohdee
Mar 15, 2016NETGEAR Expert
Those errors appear to come from the minidlna database.
You likely need to have the database rebuilt as something possibly corrupted it?
Debug more with journalctl -a _SYSTEMD_UNIT=minidlna.service
espie
Mar 16, 2016Guide
Found a way to reproduce THAT specific SQL bug.
Moving videos and srt around *after* they've been scanned will trigger it.
It seems minidlnad figures out that the file moved, but it tries to re-insert the srt into the CAPTIONS table, which does fail since there is already an entry with that specific srt.
I'll have to look at the code to make sure something more nefarious is not going on, but doing "INSERT OR REPLACE" instead of INSERT ought to be enough.
Definitely has nothing to do with the memory leak...
- SkywalkerMar 17, 2016NETGEAR Expert
Historically, OOMs during a media scan usually haven't been from minidlna. In the majority of cases I've seen, there's a bad video file that the ffmpeg libraries choke on. It may be worth running a scan in debug mode to see if it's consistently getting stuck in the same spot. Try this:
# systemctl stop minidlna # /usr/sbin/minidlnad -d -i lo -R
and see what happens.
- mdgm-ntgrMar 18, 2016NETGEAR Employee Retired
The SQL issue with moving around external subtitle files will be fixed in 6.5.0 beta 2.
As for the memory leak sending in your logs (see the Sending Logs link in my sig) might be useful. - mdgm-ntgrMar 19, 2016NETGEAR Employee Retired
ReadyNASOS 6.5.0-T338 (Beta 2) is now available. Can you update to that and send in your logs if you still have issues with DLNA or if the unrelated OOM continues to occur?
