afalout's avatar
afalout
Missing space on RN316 with 5*10TB discs
Hi All,   I have ReadyNas 316 running latest firmware 6.9.3, with 5 times 10T disks (Seagate IronWolf ST10000VN0004) which is on the compatibility list (https://kb.netgear.com/20641/ReadyNAS-Hard...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 26, 2018
    You had a paused balance. The volume can't be expanded whilst there is a balance in progress. I cancelled the balance and then was immediately able to expand the volume.
    Your 4GB root volume is quite full. You should free up some space on it.
    Also after I expanded your volume I had a look at smart_history.log and saw that one of your disks is failing.
ProSupport for Business
