ipb_uk
Nov 15, 2016Aspirant
Missing volume, dead disk.
Hello, Disk 6 on my RNDP6000 has been detecting increasing pending sector counts. I’ve ordered and received a new disk. Now for some reason it reported disk 4 dead. I’ve shut it down and pulled ...
vandermerwe
Nov 15, 2016Master
I assume you were set up with xraid single redundancy or raid 5, and it also sounds like you have no backup?
If you have no backup and you need to try to retrieve the data, your best option would be to contact Netgear support and ask for data recovery, this will cost money.
It does not look good though.
JennC
Nov 15, 2016NETGEAR Employee Retired
Hello ipb_uk,
You have mentioned that you have shut down and pulled the disks out, you need to be careful when doing this as it will break the RAID causing data loss when you improperly inserted the disks and booting up the NAS. It is best to label them so you are sure you are inserting the disks back to their respective bays before starting up the NAS.
There is a possibility that there are more than one disk that had problems.
Have you checked if you were able to get to the files after you removed disk 6 and before replacing it? It does not look good like what vandermerwe said. You may need to avail data recovery service.
Welcome to the community!
- ipb_ukNov 15, 2016Aspirant
Hello,
I’ve been here before mdgm help me out that time. I couldn’t find my login details, requested a password on my email account.
The disk are labelled 1 to 6, been there and got the t-shirt.
Yes it’s xraid single. It’s ALL backed-up on dvd’s.
I took the disks out when the system was off, tested them, then put ‘em back in and turned it on. Then a resync failed, but I could get to my files and after a reboot, no volumes.
I think I got unlucky somewhere.
If I’ve got to bite the bullet here, then I’ll have too.
Regards
Ian
- JennCNov 16, 2016NETGEAR Employee Retired
Hello ipb_uk,
This issue you have has something to do with recovery the data already.
I don't think mgdm does data recovery.
Let's see if he has something else to suggest.
- ipb_ukNov 16, 2016Aspirant
Helle JennC,
I was giving mgdm a name check only. As I hadn't done so here in this new forum.
The sixth disc isn't good any more. I've got a new red 6TB disk and I've tested that disc in the box on it's own and all is well with it.
If the remaining 5 discs have lost thier volume I can see I have no choice but to start again. And if so I have some more options to consider.
Many thanks & regards
Ian.
