benpil2
Jan 08, 2022Follower
Mon NAS pas visible sur mon réseau ni avec raidiator - help !!
bonjour, Je veux rémettre en route mon NAS et le backup par cette méthode. J'ai - reformatter mes 2 disques durs de 2 To - essayer de remettre un restore factory du nas mais cela ne semble pa...
microchip8
Jan 08, 2022Master
English, please. Also, wrong forum; try here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/bd-p/readynas-general
michaelkenward
Jan 09, 2022Guru - Experienced User
- StephenBJan 10, 2022Guru - Experienced User
Try powering down and removing the two disks (labeling them by slot).
The power up, and see if RAIDar finds the NAS. You won't be able to log in the web ui, as the OS is installed on the disks.
- SandsharkJan 11, 2022Sensei
I believe you are confusing RAIDiator (the operating system loaded on the NAS) with RAIDar (a utilty for accessing the NAS from a PC or Mac). Your NAS does use RAIDaitor 4.1.x, but as newer version or RAIDar will work fine.
