eton
Jan 12, 2015Luminary
Monitor rsync daemon?
Is there some way to view what rsync is doing during a backup job when rsync is running as a daemon? Maybe something similar to rsync -v, to monitor what files are being copied.
abickerton
May 10, 2015Aspirant
If you look at the (truly hideous Perl code) /frontview/bin/backup then you can modify the command that's being executed. I would suggest teeing to a temporary log file.
