eton
Jan 12, 2015Luminary
Monitor rsync daemon?
Is there some way to view what rsync is doing during a backup job when rsync is running as a daemon? Maybe something similar to rsync -v, to monitor what files are being copied.
eton
May 17, 2015Luminary
abickerton wrote: If you look at the (truly hideous Perl code) /frontview/bin/backup then you can modify the command that's being executed. I would suggest teeing to a temporary log file.
Thanks abickerton! I've missed that one.
That file might need further scrutiny.
