BlackEyedAngel
Jun 18, 2009Aspirant
Most efficient way to move files between shares
I have a large quantity of media on my ReadyNAS NV+ which I want to move from share A to share B. Using my PC to do this is very tedious (it's estimating nearly 20hrs to move about 200gb) - am I ri...
ivanek
Dec 01, 2010Aspirant
dbott67 wrote: Hi Ivan,
You would create create a new session with the following information:
Host name: IP address of NAS
Port number: 22
User name: root
Password: your admin password (default is/was 'netgear1')
File protocol: SFTP
Thanks a lot. Which one of Add-ons do you recommend for this purpose? EnableRootSSH orToggleSSH?
Do you think thhis Security Alert: "Opening up your NAS to SSH with password authentication on a public network is a bad idea. In my situation I'm behind a firewall and simply using SSH for the convenience and to play around with the protocol." from http://blog.epdoc.com/2009/11/ssh-on-readynas-nv.html should be considered?
Thanks
Ivan
